La suite au prochain numéro
[D3ido] 205 CTI 1.6l 115ch 10/03/86 - RESTAURATION !
Re: [D3ido] 205 CTI 1.6l 115ch 10/03/86 - RESTAURATION !
Le compartiment moteur :
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj71q24ej1ajstb33sht.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj71bop166gk7p1nve9tau.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj7eh2n47s7u134j1ndkv.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj71d31gcmmu2fln1ts310.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj81ipre331c0c179rue11.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj8o1au7o2fm1kgm1rc12.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj819r345l1aud12fk103313.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj8o693prqkj1pop17cr14.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj81dfs15m41sqp8921ert15.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj814t0h1qjchbhi0816.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj8nut17rkgnl1kfk15he17.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj8on2knebq511vn1d4618.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj8fd11gn5l2lnb5158l19.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj83cq7foslvg9l1dkc1a.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj81b3ejj4bpb1pp71gb91b.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj87fn1v65unp14ncu6q1c.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj818fj1es46esbgs1sem1d.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj8dmvn6517csu4i16s31e.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj81gr41dpp1d7k1n04qj51f.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1affmpdj81gm41hs8t9r1jdo1k2m1g.JPG)
La suite au prochain numéro![:wink:](//twemoji.maxcdn.com/2/svg/1f609.svg)
La suite :
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u8195lm141g12v63mh2c1t.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u8191uqoe7v12a48me88fu.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u81918371hlrphd13m7lifv.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u819d2d1d16g9sl14gs10.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u8191brj1k2u1hkq1fgj1nrj11.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u81913sl1c27acs1jdarh712.JPG)
Décapage :
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u8191e1u1a951rdjekc1a2c13.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u8191mt330qd8i1reuiah14.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u81915v21lrlokl3lf30d15.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u81914nml3o1qoo15co16mk16.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u8191hpj1rbcjcf1g5j14s817.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u8191dl68u148n1oqn13b518.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u8191bre1v95gnkmbbqrp19.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u819133nrdususvhrmtj1a.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u8191htqjuaqjh5d88rk1b.JPG)
n° Pininfarina :
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u8191k5jga317v3r3q3ko1c.JPG)
O'trouille :
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u819b891fjq1jhn1abli6s1d.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u819p541cc0o40a1l1p9u1e.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u819ivod573aurpllkh1f.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh7u81a1pvp1s1m7no4voeo41g.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcq3pnrqrav71ugu15v0o.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcq10jr4p0lvs1vhr1oknp.JPG)
Cachage :
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcq67tfch1ob1d8vs1cq.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcr1crk17jl15sb1f37kcbr.JPG)
Mise en apprêt :
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcri4ab2r30c1dg011gjs.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcr1k6p8db1udi6i0n14t.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcr3mk9m7n86utb15s2u.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcrmhf1olca7f1u0gju8v.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcrl4ngeslv7qadk7k10.JPG)
Decachage (avec un peut d'aide !)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcr7vnn1gteb79q8s011.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcr1pq5144uose19rr1dm12.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcr1l8er2rjbt1nrs17is13.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcr59b13ulfda18d21fc514.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcrod31ktggcdjvighq15.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afh8gdcr1qcn1q0k4levn01ofk16.JPG)
A suivre![Wink ;)](./images/smilies/wink.gif)
Décapage :
n° Pininfarina :
O'trouille :
Cachage :
Mise en apprêt :
A suivre
- vincou
- Membre du Club 2024
- A remercié : 1 fois
- A été remercié : 68 fois
Un travail de titan .
Membre du Var Auto Sport .
Allez, je continue avec l'une des option qui sera monter sur la CTI : les morettes !
A la reception :
![Image](http://www.planete-205.com/planimg/d3ido_o_1afq3a072ed8j5u2ji1ltb1rv6l.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afq3a0721rkh1eek12671jgsv7mm.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afq3a072s2s1pvo8gkopf1b6kn.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afq3a0731ver1nj95du11mvj0ko.JPG)
La restauration : décollage au four (et peinture chromé doré uniquement pour le test - je n'avais que ça)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afq3a0731iee1k3e112e159m1n79q.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afq3a073821fq01sf21pq99ggs.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afq3a073188q1htk11cvi1hph2t.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afq3a0731sgi3ojomv1583ciiu.JPG)
Des globe jaune :
![Image](http://www.planete-205.com/planimg/d3ido_o_1afq3a073183ih11mlm1ndl12nhr.JPG)
Et un montage a blanc sur la GLD pour voir le rendu :
![Image](http://www.planete-205.com/planimg/d3ido_o_1afq3a073f4rij01vpoqo8ggip.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afq3a073sqkj0m633jefqjb10.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afq3a073su71vdc1lm5e096acv.JPG)
A la reception :
Des globe jaune :
- vincou
J suis pas fan des morette a voir une fois fini .
Le moulin est presque près ! (ne manque plus que le support d'alternateur et le cache de distri -et par la suite quelques durite...-)
Je m'excuse d'avance, je n'ai plus les photos de la réfection moteur faute a un tel qui ne marche plus... On été fait : épreuve et rectification du plan de joint, joint de culasse, distri, galet, pompe à eau, TOUT les joint papier, l'embrayage, TOUT les joint spy, le joint de carter d'huile et de couvre culasse, les jeux au soupapes ont été contrôlé et les compression moteur également ! Pour finir les injecteur ont fait une petite cure de jeunesse![Smile :)](./images/smilies/smile.gif)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afsl24h8bhc1t01e6fu6togcg.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afsl24h818md6t21764ojf1ki5h.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afsl24h8a7tl15o2am7o1b87j.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1afsl24h9dg71fj51itrff4psk.JPG)
La culasse de 105 qui a aussi été contrôlé
![Image](http://www.planete-205.com/planimg/d3ido_o_1afsl24h8te91i7n192k11l8m0ki.JPG)
Le nettoyage des injecteur par Steven
![Image](http://www.planete-205.com/planimg/d3ido_o_1afsl24h91al2hekqi3nk319s5l.JPG)
Et retour a la maison :
![Image](http://www.planete-205.com/planimg/d3ido_o_1afsl24h91e0p16qt13r1r6qct7m.JPG)
- stevendesrallye
- A remercié : 237 fois
- A été remercié : 451 fois
c'est pas la bonne photo pour les injecteurs ![Wink ;)](./images/smilies/wink.gif)
Ha! en effet !
Erreur de tri... c'est ceux de la Supra ![Oops :blush:](./images/smilies/blush.gif)
![Razz :p](./images/smilies/tongue.gif)
- A remercié : 20 fois
- A été remercié : 78 fois
tu as déjà fait une présentation
autant les fusionner
http://www.205rallye.net/forum/viewtopi ... ilit=D3ido
![Ok :ok:](./images/smilies/enaccord8.gif)
Il manque la moitié des photos... mieux vaut complètement le supprimerzergo a écrit :tu as déjà fait une présentation![]()
autant les fusionner![]()
![euh :huh:](./images/smilies/huh.gif)
- jerem205rallye
- A remercié : 26 fois
- A été remercié : 11 fois
Au top les morettes ![Ok :ok:](./images/smilies/enaccord8.gif)
205 GTI 1l6 AM 85 - gris futura
205 GTI 1l9 AM 87 - gris graphite
205 rallye AM 88 - blanc meije
205 rallye AM 89 - blanc meije
viewtopic.php?f=39&t=41510
Je continue : Dépose de l'aile ARG (avec plus de photo que sur la droite)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc38s1ce71jgvd91cpos.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc31iuf1pcg36n175ks3et.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc3uih1f9tt0ve0v1nisu.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc31lst7091i5n1hj2192ov.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc31nni1n7a1vm91vphdts10.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc34h17urogkbqt11t011.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc3hmm1kol1ak01e2h1ehf12.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc3192r1f4c1mn7hk069l13.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc4spjuv881pag176j14.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc41m0ukid16rjbq5mah15.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc4197a1pdbuefefkbho16.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc41n7b38g1u8i1l62n5017.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc41kv81nej1s0s7ji1n518.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc4ioljdm14qhrru1kt119.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc4svn1lcdlc91djq1ch31a.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc4odo3v41eo4l3i1n2g1b.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc413r11f4ek97icv176o1c.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc4a8g1v9a6jo1tl36tn1d.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agc8rmc48p71gtfmd0uda14vv1e.JPG)
A suivre![Happy ^_^](./images/smilies/happy.gif)
A suivre
Comme vous l'avez remarqué les tôle d’intérieur sont bien attaqué, j'ai donc dût récupérer une donneuse pour cela :
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrojvmbsmmsvvmq6uq1i6ca.JPG)
(je ne l'ai pas tracté comme ça sur la route, c'était seulement pour faire les manoeuvre et la placer sous mon hangar)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbqu2r76r1u9f7ib8l10.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbq13m11cm8qje1err72t11.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbqs5m1lp61tvvvhom012.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbqhmc1452a47js3ijo13.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbq3gp1uaqsof1c0p1fnk14.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbqh207gbd9q19k3174315.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbq6bj186011takq41sth16.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbq13s71acp1et1spfd3117.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbq1dmkmal4813bdjud18.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbq122l1cjr1kbs1321qka19.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbq1cpj1svq1sgc1dsd3c01a.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbq1lk1rp28qk1sgl1hcm1b.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbq1keu1jub4boeeg1ihf1c.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbqt3911b82kev98861d.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbr1ovv3lg1rgr1hn418mf1e.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbrgr7167e19n0t8aqpg1f.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbr1f0j1g3uu0r1b4f19g01g.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbr176g15ocdmd1hgl1l8u1h.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1agjrosbr1b3o1lpassd7ih1j841i.JPG)
Elle est du 9/10/89, j'ai les papier mais comme vous avez pus le voir, sa restauration serait compliqué....
Au programme sur cette donneuse, récupération d'une partie du faisceau (ou du moins de ce qu'il en reste), des deux tôle d’intérieur d'aile, du circuit de freinage, d'une partie du train arrière et du train avant ! Le tout pour la modique sommes de 150€ ! (soit le prix que m'aurais coûté les canalisation de frein en neuf) Ha! et j'oubliais, le cul servira de base pour faire une remorque carrossé
A suivre
A suivre
- patladoze
- A remercié : 284 fois
- A été remercié : 242 fois
ta quand même un boulot de dingue...mais tu a l'air motivé alors bon courage et félicitation pour le boulot déjà accompli
![Image](https://smileys.surlatoile.org/repository/Combat/2guns.gif)
Alors, après une absence sur le forum de près de deux mois... (pas beaucoup de temps en ce moment) Voici la suite :
Récupération de la tôle de renfort d'aile sur la donneuse :
![Image](http://www.planete-205.com/planimg/d3ido_o_1am9a5b5m753imd7dhgh518lpf.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1am9a5b5mhus7qo13b8hi1mb3g.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1am9a5b5m19l6141teht0v602h.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1am9a5b5m1mdt1b4ofb0bheeqji.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1am9a5b5mutg1fm8u2vd5hpfhj.JPG)
![Image](http://www.planete-205.com/planimg/d3ido_o_1am9a5b5muka1qmq1q3q1t2ihefk.JPG)
et en attendant que je tri la suite des photos, voici mon armoire a peinture :
![Image](http://www.planete-205.com/planimg/d3ido_o_1am9abc431npivnvcm62ovleb26.JPG)
A suivre![Smile :)](./images/smilies/smile.gif)
A suivre
