AX lack of power
AX lack of power
Message par AX lack of power »
Hello from Zagreb Croatia! I dont know French so i`ll try in English..... I own AX 1.4 with 205 Rally head (lightly ported), camshaft and Webers 40 dcoe. Car is going fine untill 6500 rpm an then it starts to loose power drasticly. Venturies are 34mm, mains 140 F9 200, idle jets are 50. Does anyone has an idea how can i get little more efective rpm out of it? My carbs dont have vacuum conection that goes to distributor. Can that maybe the problem that it doesen have enough advance?
Thanks very much!
Andrej
Yves
Message par Yves »
Hello,
Are you sure that your carbs are tuned correctly ?
I had quite the same problem with my Ax sport (same engine than 205 rally) and the problem was that my mixture was far too lean, so I made the mixture richer with the idle richness screws and now everything works fine... seems strange because the idle richness screws should normaly have no affect on higher revs but if the mixture is too lean below 3500 rpms it will become even worse at higher revs.
Don't know if this will help but is worth give it a try ?
yves.
Has thanked : 643 times
Been thanked : 614 times
i think you can have a look at your inlet and exhaust valves gaps,and of course make sure that your carburettors syncronisation and mixture are corcetly tuned ;)
Guest
Message par Guest »
oliv'fast&furious a écrit :i think you can have a look at your inlet and exhaust valves gaps,and of course make sure that your carburettors syncronisation and mixture are corcetly tuned  ;)
How much must that gap be? I found many data. Some said ... inlet 0,20 exaust 025,030, 040.
This is 0.20 for inlet valves and 0.30 for exhaust valves ;)
:huh: j'suis con ou c'est un 1400 avec un culasse de Rallye <_<
Oliive a écrit ::huh: j'suis con ou c'est un 1400 avec un culasse de Rallye <_<
je sais pas :huh: j'ai du mal à comprendre l'anglais des fois :D
Guest
Message par Guest »
oliv'fast&furious a écrit : This is 0.20 for inlet valves and 0.30 for exhaust valves ;)
So it is. I will try to put carbs with that vacuum for distributor. I think that`s a problem. Not enough advance at high rpm.
