carburettor manifold gasket
thiscocks1
A remercié : 21 fois
A été remercié : 8 fois
Message par thiscocks1 »
Hi, I wondered whether anyone can help with finding this plastic gasket which connects the carb to the inlet manifold?
The one in my car has small cracks in it and they seem very hard to find a replacement in the UK!
Regards, Tim
A remercié : 2603 fois
A été remercié : 1773 fois
Re: carburettor manifold gasket
https://www.bps-racing.com/bride-carbur ... -40mm.html
Caution to the rigid gasket. Well keep silent-bloc with lower support.
Very difficult in France also.
Reconstruction is being studied by Peugeot classic.
thiscocks1
Thanks for that. :ok: I will try this metal one. I assume the lower support is already on the car as standard? I haven't looked under mine properly yet!
thiscocks1
Very interesting :ok: The engineering drawing could be useful. I may see if I can get it made in plastic to those measurements. Thanks
thiscocks1
jean a écrit :https://www.bps-racing.com/bride-carbur ... -40mm.html
Hi Jean, do you know if this definitely fits to the Solex addhe 40? Just about to order them :)
Yes it is !
This is the same between Solex Addhe and Weber 40
thiscocks1
Now with the new metal gasket on!
Now just need to sort out the sticking throttle. Possibly will be a full carb re-build.
ying-yang
A remercié : 125 fois
A été remercié : 44 fois
Message par ying-yang »
Hello,
Beautiful !
Are your carburettor manifold gaskets fortal (aluminium 7075) ?
thiscocks1
Thanks, yes they are aluminum, not sure exactly which type but could be 7075 as you say. I made up paper gaskets. Runs much better now :)
